Safety Precautions When You Bolt Into Concrete
Whenever you find yourself needing to bolt into concrete, there are a few things that you will need to keep in mind. It is important to practice safety whenever you are doing any task. This is especially true for whenever you are working with concrete. Make sure that you not only know how to bolt into concrete before you begin but also that you know how to bolt into concrete safely.
Machinery Used
The machine that you use needs to be one that is going to be a good one. You will find that you will be starting off right if you have a machine that is going to be able to provide you with safe and accurate work. These machines can be as cheap as $30-$40 or as expensive as $200-$400. There are several different brands of hammer drills out there.
Some research will be necessary to make sure that you get the best one for your needs. This means seeing what each one does and what its strong points are so that you can make an educated decision about whether or not it is the right one for you. It is a good idea to go with a brand that you already trust and are familiar with. Read up on the manual and know what each control and knob does.
Proper Handling
Whenever you are holding onto your machine, you will need to know the proper way to do it. You will start by putting the masonry drill bit into your hammer drill. Make sure your safety glasses are on at this point. The depth gauge of your hammer drill should be set according to the manufacturer’s instructions.
Electrical tape will need to be wrapped around your masonry drill bit. The bottom of your electrical tape will need to be aligned with the depth gauge of your hammer drill. Your masonry drill bit point needs to be put up against the concrete where the bolt will go. Drill the hole and stop only when the depth gauge meets up with the concrete. You need to have a good, firm grasp on the machine.
Preparation
It is important that you are prepared before you begin to bolt into concrete. Because this is a task that needs so much of your energy and attention, you will need to make sure that you are able to be fully prepared for it once you begin. Make sure that you know the exact locations on the concrete that you plan on bolting as well as how much bolting you will need to be doing.
Basic Precautions
Whenever you are bolting concrete, you will need to protect yourself completely. The best way for you to do this is to wear protective clothing as well as gloves and safety glasses. Concrete can be very dangerous whenever it is being bolted as small pieces can come flying off and hit you.
