Saltillo Tile Cleaning: How to Clean Saltillo Tile
Broom
Mop
Saltillo tile cleaner
Sponge
Warm water
Saltillo tile cleaning involves specific supplies, and specific steps that need to be taken. This type of stone needs to be taken care of to keep it's beautiful appearance. Below you will find the items needed to clean your saltillo tile, as well as the steps that should be taken to do so.
Step 1 - Sweep
The first thing you will need to do is sweep and vacuum the entire surface. Make sure you get rid of all debris on the tile, before moving onto the next step.
Step 2 - Rinse
Now, you must rinse the entire area with warm water, then you will take your sponge and scrub with just the water present.
Step 3 - Apply Cleaner
It is time to apply your tile cleaner. Make sure that the cleaner you have purchased is specifically for saltillo tile, and is a deep cleaner in order to get rid of grime and grease that is present.
After you have applied the cleaner, let it sit for about 7 minutes, and then use your sponge to scrub. Rinse again with warm water.
Saltillo tile is a gorgeous tile, and if taken well care of, it will remain that way for a very long time.
