Selecting a Pond Heater
A pond heater is a must have if you have a fish pond at home. During the freezing winter months, the water of the pond becomes very cold and thus poses a problem for the aquatic plants and animals. The pond heater helps maintain the temperature of the pond and ensures no harm is caused. There are various factors to keep in mind while selecting a pond heater, a few of which are discussed below.
Option 1: Based on Heating Needs
As winter progresses, a thin layer of ice starts forming on the surface and can be very dangerous for the aquatic creatures. Floating pond heaters are used to heat the surface of the ponds during winter to prevent ice formation. If you want to heat the depths of the pond, you will have to buy the submersible pond heaters which can do this work very efficiently. A submersible heater can heat water over a large surface area as compared to its floating counterpart.
Option 2: Based on the Mode of Heating
You have electric pond heaters and heaters that work on heating coils. Electric heaters were among the first set of pond heaters that came into the market. Though a lot of people use this, it is not highly recommended because of the possible threats it poses. There are chances of short circuit that can kill all the fish in the pond. Chances of a person getting electrocuted are also high. In comparison to them, heating coils take an upper hand because these are easy to use and not as dangerous. Another benefit is that these coils are available at an affordable cost.
Option 3: Based on Size
You have pond heaters that are built to suit the size of your pond. If you have a small pond with few plants and fish, then, you can go in for compact heaters.  These equipments are small and user friendly. They also have a very contemporary look and are very reliable. If you are looking for pond heaters that are technologically advanced and capable of running by themselves without a lot of intervention from your end, then, compact heaters come highly recommended.
However, if you have a pond spanning a large area, then, you have to go in for bigger heating systems. Though they are also dependable and easy to use, they are not as technologically advanced as the compact ones. If you go in for a bigger pond heater, you will also have to make sure that it is placed in a secure place. You will have to be very careful while making this selection because a large heater when not needed can prove to expensive and waste energy while small heaters for large ponds will be ineffective and cannot meet the heating requirements.
Option 4: Based on the Type of Fuel
There are pond heaters that run on oil, gas and electricity. You can go in for the one that best suits your requirements and budget. The heaters that run on oil and gas have high set up costs; however, in the long run they turn out to be inexpensive and easy to maintain. In comparison, the heaters that run on electricity are not expensive initially; however, their maintenance costs are higher and can pose greater threats as compared to the oil and gas heaters.
For more information, you can look for types of pond heaters to see the options available and choose the one that is best suited for your pond.
