Sewer Backed Up? Take These Immediate Actions
There are backed up sewer issues that you will have to face once the problem occurs because it is considered as a kind of bio-hazard. It must then be treated as such during the cleanup. If there are plumbing and flooding problems, the backup from your sewer can invade your home by way of the tubs, showers or toilets. It is always a nasty and messy job to clean it, and generally, you only have 2 choices: clean it up by yourself or hire a professional to do it. If you choose to have a professional help, it might cost you a substantial amount of money. Hence, you will usually be left with one choice, and that is cleaning it up by yourself.
Health Hazard Considerations
When cleaning up your sewer backup waste, always take some steps to prevent the waste from coming into contact with you. Heavy duty gloves that are made of rubber and goes up all the way to your elbows would be a good protection. You should also not do it without a face mask and rubber boots. To prevent the germs from spreading throughout the house by way of the soles of your boots, sanitize it after the task. Wearing a face mask is essential since you can be sick by inhaling the backup waste fumes directly. In addition, make sure that your working area has proper ventilation. Open all windows in the area and circulate the air by means of electric fans.
Waste Removal
Waste that comes out of a sewer backup should be removed immediately. Take out anything that is porous which has come in contact with the wastes. These would include cardboard, paper or Sheetrock. All carpets and carpet padding that has been soiled must also be removed. If the waste products have come in contact with press board, you will not be able to salvage it, and same with cushions and other upholstered furniture. These household items cannot be sanitized effectively, and removing them from inside your house would be your only option. There may also be a need to rent a dumpster to hold the discarded items from your home if the damage has been extensive. If it only affected a small area, use heavy duty trash bags that are large enough to effectively hold your discarded materials.
Cleaning a Sewer Backup
There are a lot of germs and bacteria that can infect your home as a result of a sewer backup. Removing them effectively can be done by a bleaching product. Immediately rinse all surfaces that can be safely washed with hot water. To make a thorough sanitizing cleanup on the area, mix a cup of chlorine bleach to a gallon of hot water. With a sponge, use the cleaning solution to wipe all surfaces that may have come into contact with waste materials. Use a brush if there is a need to brush an area and rinse everything afterwards with hot water. Make sure that you clean everything and then allow to dry completely.
