Sewer Line Cleaning Tips
As it is the drain through which all the other drains in your home expel their contents, it is important to familiarize yourself with the proper method of sewer line cleaning. If not cleaned on a regular basis, your sewer line can become clogged or fall victim to an onslaught of roots. Fortunately, with the help of the following tips, you'll find that the sewer line cleaning process is actually quite simple.
Tip 1 - Use a Garden Hose for Basic Cleaning
One of the best ways to clean a sewer line is to use a garden hose. Simply insert the hose's nozzle into your sewer line's clean-out plug and give the line a good spraying. This tip is best utilized when cleaning a sewer line that is not terribly dirty or one that has recently fallen victim to a stubborn clog.
Tip 2 - Promptly Take Care of Roots
Another great sewer line cleaning tip is to keep roots away from the line. Intrusive roots are a common problem, one which needs to be addressed quickly. Make a point of clearing away any roots in the immediate vicinity, as they have a propensity for finding their way into lines. For best results, perform a weekly root check in the spring and summer when plant growth is most abundant. Minor root buildup can often be tackled with a commercial root-clearer.
