Quick Information on How Felt Padding Helps Your Basemen Carpet Quick Information on How Felt Padding Helps Your Basemen Carpet
When installing carpet in your basement, you should use felt padding. It will give your carpeting a more luxurious feel when you walk on it, and it will help keep the carpeting from breaking down as quickly. Creating a barrier between the basement floor and the carpet will not only make your carpet last much longer, but it will also serve as a barrier to capture moisture. Felt padding will absorb very well and allow the moisture to evaporate. It will keep mold and mildew at bay, which will not only save your carpet, but also reduces the risk of health issues and bad odors.
