Should Metal Sealant be Spray or Paint Form?
A metal sealant can protect a metal finish from corrosion and rust. This type of sealant will also add an extra layer of shine to protect the look of the metal, and it will take much longer before the finish deteriorates again. Over time, metal will develop wear such as scratches, rust and oxidation due to water and air elements, but a metal sealant can delay or prevent this damage from happening.
Forms of Metal Sealants
Metal sealants come in 2 forms: spray and paint. The paint is a liquid that must be painted on the metal surface with either a paintbrush or roller. This is recommended for smaller metal surfaces, such as metal beds or plumbing pipes.
For larger surfaces to cover, a spray metal sealant is better because it will be applied more evenly. And since most metal surfaces will be larger, it will be easier to apply rather than just painting it on. If the surface is big, such as a metal roof, spraying it will be more time efficient because spray sealant will give of larger amounts every spray application.
