Snap up These 13 Lawn Care Deals on Amazon Prime Day
Summer is here, which means fun (and work) in the sun. Amazon Prime Day on July 12th and 13th has got you covered with deals on tools, furniture, camping gear, and more. Here are a few deals that caught our eye.
You have to be a prime member to get these deals. If you're not already, you can sign up here.
1-3. Ashley Outdoor Furniture
If you’re aiming to freshen up the deck with some resting spots, this set of two cushioned wicker chairs might be just what you’re looking for.
Highly rated and completely assembled, these aluminum-frame chairs could be on your porch or patio before the end of the week. Also enjoy the nearly $300 discount on Prime Day.
To complete the look, the Wicker Patio Sofa is discounted by more than half, and the Eucalyptus Loveseat by the same brand is reduced by over $300.
4-7. Intex Pools
Whether you’re replacing a previous model or setting up an above-ground pool for the first time, prep your space with level ground and a fresh layer of sand.
Consider options like the ultimate setup with the 18ft x 9ft x 52in Ultra XTR Pool Set with Sand Filter Pump for summertime fun for the entire family. Expect this size to be around $400 off with similar discounts on other sizes.
For a different style, check out the #1 best-selling pool, the INTEX 26167EH 15ft x 48in Easy Set Pool with Cartridge Filter Pump, which will be discounted about $120. The larger INTEX 26175EH 18ft x 48in Easy Set Pool with Cartridge Filter Pump will be discounted from $550 to $380.
If you’re looking for a sand pump to go with your above-ground pool, check out the INTEX 26643EG SX1500 Krystal Clear Sand Filter Pump for Above Ground Pools, which is highly rated by over 14,000 customers, and over $100 off the regular price.
8. Keter Kentwood 90 Gallon Resin Deck Box
Spruce up the pool and patio space with an organizational tool that keeps the pool noodles and throw pillows hidden and protected from the elements.
This deck box comes in brown or graphite color options and will be priced around $110.
9. Greenworks 40V Cordless String Trimmer and Leaf Blower Combo Kit
If you’ve been considering going rechargeable for the benefit of the planet or simply because being cordless is convenient, grab hold of this deal.
GreenWorks is a recognizable brand in the battery-powered world. This combo set allows you to take advantage of one battery for two devices.
With both a leaf blower and a string trimmer, you can keep your lawn, driveway, patio, and walkways looking great. Regularly around $155, this combo will be a deal of the day at around $82.
10. Sun Joe SPX3001 2030 PSI 1.76 GPM 14.5 AMP Electric Pressure Washer with Hose Reel
Clean up your act with this electric pressure washer for the driveway, house siding, patio, deck furniture, and much more.
The setup comes with five quick-connect nozzles (0º, 15º, 25º, 40º + soap), high-pressure hose, garden hose adapter (female coupler), and needle clean-out tool.
It features an onboard hose holder for an organized and compact appeal. It will be around $50 off regular price for the Amazon event.
11. Cutter Mosquito Fogger
Mosquito season is either already here or likely on its way. Get prepared with a backyard bug control fogger. This two-pack addresses several types of flying/biting insects and covers up to 1,200 cu ft with each can. The pair will be about ½ price on Prime Day.
12. Aqua Joe SJI-OMS16 Indestructible Metal Base Oscillating Sprinkler with Adjustable Spray
Ranking #1 in lawn and garden sprinklers sold through Amazon, this sprinkler maintains high ratings by over 18,000 customers.
It can cover up to 3600-square feet and is made from alloy steel for durability. Sale price is about $12.
13. Keter Urban Bloomer Raised Garden Bed
It’s a self-watering, waist-high garden center to make the job of growing plants much easier with better harvests. A water gauge lets you know when it’s time to add moisture, and the reservoir and easy drainage lets you easily monitor water levels.
Happy shopping!
