Spot Cleaning Flat Woven Rugs
Spot cleaning flat woven rugs is a simple task that will help restore its natural beauty for years to come. All you need is a little elbow grease and some common household items and you’ll have your rug looking as good as new.
The first step in cleaning flat woven rugs is to give them a good vacuuming to remove all the loose dirt and debris that’s trapped between the interwoven fibers. Regular vacuuming is recommended as part of maintaining your rug and will also prevent stains from developing.
Once you’ve finished vacuuming, the next step in cleaning flat woven rugs is to gently blot the affected areas with a cloth dipped in your homemade cleaning solution. Consisting of a teaspoon of detergent, a teaspoon of white vinegar, and two quarts of warm water, this solution is gentle on your rug yet strong enough to remove the toughest stains. Repeat the steps until the stain has been completely removed and then dry with a clean towel.
As you can see, spot cleaning flat woven rugs is a quick project that will return immediate dividends in the appearance of your room.
