Spray Foam Insulation Spray Foam Insulation
Spray foam insulation is an alternative to sheets of spun fiberglass for weatherproofing attics, walls, ceilings, and crawl spaces. This home-improvement alternative can be more costly, but spray-in foam installation can also provide greater insulation and soundproofing.
What Is Spray-Foam Insulation?
Spray-foam insulation is generally made from polyurethane. It typically requires professional installation, because specialized machinery is required. Spray-foam insulation has the same purpose any other type of insulation. It creates a barrier that holds in heat during the winter and keeps homes cool in the summer. It also helps keep attic temperatures from interfering with the home’s cooling or heating systems and their efficiency.
Advantages of Spray-Foam Insulation
While spray-foam insulation can be a more-costly purchase, it can deliver advantages that make its installation worthwhile. It molds to fit nooks and crannies, thereby providing a better seal. It is also just about the most efficient insulation you can get.
