Staining Siding: 3 Mistakes to Avoid
When staining siding, especially if this is your first time, there are a few things that you want to keep in mind. Here are some common mistakes to address that can help guide you through your project with ease:
Mistake 1 - Not Testing Materials
One of the biggest mistakes is not testing the stain on the siding. Be sure that before you coat the entire side, you test out one side. This way you can see how the stain will look before finishing in case you do not like it. Stain one small corner or an extra piece if you have one and allow it to dry for the correct amount of time.
Mistake 2 - Not Using Outdoor Stain
Using the right stain makes a huge difference. When you are working on siding, you have to be sure that you use an exterior stain. This keeps the siding protected even when the weather is harsh.
Mistake 3 - Not Preparing the Siding
Another huge mistake is not cleaning and prepping the siding before you stain. Dusting any dirt or debris and then washing the siding completely will help to ensure that you don't have any bumps in the final look. Also, the stain will go on evenly and smoothly.
