Stamped Concrete Patio: Pros and Cons
A stamped concrete patio is increasingly becoming a hallmark of outdoor installations. This is a concrete patio that has the preferred design stamped onto it before it dries out. A textured finish may also be used to decorate the concrete. It is an ideal way of adding beauty and value to your outdoor space.
The improved ambience of a stamped patio boosts relaxation in the patio. Selecting the right patio finish requires considerable thought. An ideal finish should give you the proper aesthetic and functional value of your home. Perhaps you are considering having a stamped concrete finish for your patio. Below are the pros and cons.
Benefits of Stamped Concrete Patio
Stamped concrete costs considerably less than traditional pavers to install. Yet its versatility will give you practically any look you desire. You can select whatever color, style or pattern that suits your needs. Stamped concrete can be made to resemble most other materials, whether traditional pavers, blocks, natural stone, seamless stone or slate.
Stamped concrete can enhance the aesthetic value of your outdoor space. This ultimately adds to home value especially when the patio is well maintained. It also enhances outdoor ambience considerably. Relaxation and entertainment are better enabled and appreciated on a stamped patio. Benefits can also be appreciated when it comes to maintenance. You are less likely to be troubled by weed growth with a stamped concrete. The finished surface does not allow weeds to sprout unlike traditional pavers or blocks.
It is also easy to clean a stamped patio. All you need is a regular detergent with water. A stiff bristled brush or pressure washer can be used to get off surface dust and dirt.
Disadvantages of Stamped Concrete Patio
Installing stamped concrete is a long process. Specialized equipment is required to stamp the desired pattern onto the concrete before it dries out. The technicalities involved in pouring out the concrete onto the patio are also a challenge. It is a laborious and time-intensive process although the finished look is well worth the effort.
Regular maintenance is necessary to keep your patio looking good. If you neglect periodic maintenance, cracks fading and dustiness are likely to occur. A sealant must be applied every couple of years. It is also a good idea to apply an anti-skid formula to prevent possible skidding, especially when wet.
A stamped patio has a low adaptability unlike traditional pavers or blocks. You are limited in developments. You will be compelled to remove the entire portion if you desire a change. You cannot extend or shrink with ease unlike pavers. Since cracks will inevitably develop on stamped concrete, you must be prepared for added costs over time. This puts the durability of stamped concrete on the lower side when compared to pavers. Although it may be a cheaper alternative to pavers this may only be an initial benefit. Maintenance and repairs add to the overall costs.
