Stamped Concrete Patterns: 2 Styles Stamped Concrete Patterns: 2 Styles
Stamped concrete patterns allow homeowners to transform a boring concrete walkway or driveway into a beautiful space mimicking the look of natural brick, stone, cobblestone, or wood. There are several different options when it comes to pattern selection. The following are two popular choices.
Cobblestone
One of the reasons stamped concrete is becoming more popular with homeowners is that it can be made to look like a number of different surfaces for less money. One option is to create the illusion of a cobblestone surface. A contractor creates the look of cobblestone in two ways:
  • Using stencils, stain, and paint
  • Laying down stamped and colored concrete
Stamping wet concrete is a fairly difficult process, so it's a good idea to hire a professional for the job rather than try the do-it-yourself method. With this method, freshly poured concrete is stamped to create the look of natural stone. If you decide to stamp the concrete on your own, you can buy special stamps from a concrete supplier. Here's how to do it:
Step 1
Form your patio, walkway, or driveway as normal. Mix and pour the concrete, going one section at a time. If you want to add color, mix into the cement before pouring.
Step 2
After putting down one section, place the mold onto the surface and press it down. Repeat this step until you are finished pouring and stamping all the concrete.
Step 3
Paint the surface after it has cured if you didn't add color to the cement mixture. You can also add rock salt to the surface or a colored stain on top for a look with more texture.
Brick Pattern
Brick has been a staple of the building industry for thousands of years, and its popularity continues today. Stamped concrete allows you to achieve the beautiful and unique look of brick without having to spend an exorbitant amount of money. A faux brick technique can be just as beautiful as the real thing. Stamping wet cement to create the look of brick is not necessarily an easy do-it-yourself job, but you can do it if you plan ahead and purchase the right materials. Here's what to do:
Step 1
Buy special stamps at a concrete store.
Step 2
Before stamping any concrete surface, you must properly prepare the concrete. You have to remove harmful residues before applying stains or paints as they can cause bubbling and peeling soon after application. An acid cleanser or chemical treatment works well, or you can use the blasting method to achieve a thorough cleaning.
Step 3
Press the stamps into the wet concrete as you pour it onto the ground. Different pigments can also be mixed into the wet cement to achieve the appearance of a variety of attractive brick colors.
Step 4
Another option to create different colors is to paint the surface after it has dried and cured.
Before beginning this project make sure that you are comfortable working with concrete. If not, contact an experienced contractor.
