Steel Siding Cost vs Wood Siding Cost Steel Siding Cost vs Wood Siding Cost
When it comes to remodeling the outside of your home, you will want to know the difference between the wood and steel siding cost before you make a final decision. Here are a few things to keep in mind while choosing which is best for your home and budget.
Initial Costs
When it comes to initial costs to buy and install each of these materials, wood is a little more expensive than steel. While you can expect to pay about $2 to $4 for the wood pieces, the steel can be closer to $8 to $10 per square foot.
Maintenance Costs
Both of these materials are extremely sturdy and durable. While steel tends to bend slightly over time, it still stands up to the elements extremely well. Wood is also a very strong material. Because of this, neither is expensive to maintain. However, you will need to paint and continue to maintain the wood more to be sure that it stands up to the weather.
While wood is less expensive up front, it can be a little more pricey to maintain over the years. Both are great options for siding, however, so weighing the costs can help you make this important decision for your home.
