Stone Fireplace Remodeling: 3 Ideas
Stone fireplace remodeling can seem like a daunting task; however, if you plan properly and have a lot of patience, you can bring your dream to life. There are so many options for remodeling a stone fireplace that sometimes it can seem overwhelming. If you focus on just a few ideas, you will have a better chance of actually getting something accomplished. Three of the most common ideas for remodeling a stone fireplace are painting, extending the fireplace, and adding stucco. Consider these three ideas and choose one that fits your style.
Paint
Paint is the first choice of many homeowners when they decide to give their fireplace an overhaul. This is because paint is inexpensive and the procedure is easy. If you are tired of your stone fireplace, paint can be a perfect choice. You can get creative with your color choices and really tie the fireplace into the color scheme and design of the room or you can go for a more traditional neutral color. Either way, the application process will be the same. First you will clean the stone with tri-sodium phosphate. This can be found at your local home improvement store. You will then prime the stone and apply the paint. Depending on the color, you may want to apply two coats.
Extend the Fireplace
If you have a fireplace that doesn’t include a mantle, you can run the stone to the ceiling. This will create a large focal point and can add real warmth to a cold, minimalist design. You want to check on a few things before you undertake this project. First, can you locate stones that match your existing fireplace?  This shouldn’t be too hard; however, if your home is very old or the fireplace was created by an artist, you may run into some trouble. If you cannot locate the stone, you may want to go with a different option.
Once you have determined that you can, in fact, locate the stone, you will need to consider what runs behind the wall over the fireplace. In many homes, it is simply the route to the chimney. However, if your fireplace is faux or the chimney has been rerouted in some way, you may encounter some surprises. Last, you will need to determine if you need to bring a professional on board. Stone work is not easy and is quite physically demanding. If you don’t use a professional for the job itself, you should have someone on hand if you encounter some setbacks.
Add Stucco
To get a totally different look, you can stucco over your existing stone fireplace. A stucco fireplace will afford you a number of different options. You can adjust the finish to your liking, from modern to rustic. You can also paint the stucco to any color of your choosing. There are also a number glazes and faux finishes that work well with a stucco fireplace. You will need to apply a cement backer board to the stone and make sure that it is plumb. You can then add a chemical bonder and apply two coats of stucco. The final coat should be finished to your liking.
With these ideas, you should be able to remodel your fireplace into something you really love.
