Symptoms of Black Mold Poisoning
Recognizing the symptoms of black mold poisoning could potentially help avoid serious health problems for you and your family. Toxic mold is one of the most common problems for homeowners today. There are many potential symptoms that you could experience as a result of being around black mold. Here are some things to keep in mind when it comes to mold in your home.
Difficult to Detect
Detecting when black mold is present can be very difficult based solely on someone's symptoms. There are many different types of mold and the only way to tell for sure which type of mold you have is to have it tested. Each person will also react differently to being subjected to mold, which makes it even more difficult to detect. It may appear that one person has a cold or allergies and others may not be affected at all so you might not even think to test for it. However, if you have experienced any symptoms for prolonged periods of time and there are no other explanations, black mold should be considered. Here are a few of the things to watch out for that could be caused by black mold poisoning.
1. Lack of Focus
Black mold has the ability to negatively influence the processes of the brain. One of the most important processes is the ability to concentrate on something for an extended period of time. Black mold can make it very difficult to focus on things for longer than a few seconds. If you find yourself having trouble concentrating on things and staying on task, black mold could be the culprit.
2. Irregular Blood Pressure
Many people do not realize that blood pressure problems can actually be caused by black mold. Most do not consider black mold as a possible cause because stress, heredity, and many other things can cause blood pressure problems as well. If you monitor your blood pressure frequently and notice wild swings in readings, this could be caused from black mold.
3. Respiratory Problems
One of the most common symptoms of black mold poisoning is respiratory problems. These problems could come in any number of forms. Some people experience trouble breathing or catching their breath. Other people continuously sneeze and have mucous discharges from the mold. In extremely severe cases, it has even caused bleeding in the lungs. The symptoms are often magnified by those that have asthma or another respiratory condition.
At first, you might think that you simply have allergies or a cold. However, if the symptoms persist and continue to get worse, black mold should definitely be considered.
4. Headaches
As a result of being near black mold, many people also experience regular headaches. Headaches are common enough among most people that they never consider the possibility of black mold causing them. However, if you have tried everything else and the headaches persist, you might want to have your house tested for mold.
5. Urinary Problems
Black mold can also cause urinary problems as well. You might find yourself with symptoms of a urinary tract infection. You might also have problems urinating. Some people urinate more frequently and feel thirsty all the time. All of these things could be attributed to black mold.
The symptoms of black mold exposure vary so it is important to follow up with a healthcare provider if you have any symptoms that concern you.
