Testing Well Water for Biofilm
If you have a well, then you may need to test the well water regularly. One of the things that you will be looking for in these tests is the presence of biofilm. Biofilm is a micro-organism that grows in the well water. It must to be eliminated, as it can be a source of food for other bacteria and fungi. Testing well water for biofilm is not a difficult process.
Purchasing a Tester
You can find a number of different testers that will all identify biofilm in well water. You should shop around in order to find the best price for your tester, as cost can be very important. When you are looking for a suitable tester, check that you are able to locate the indicator for biofilm easily.
Testing Well Water
You need to take some of the water from your well in order to give it a test. It is best if it is drawn up, and then immediately tested. Immediate testing prevents contamination from other sources. Use your tester to check for signs of biofilm, and also have a solution nearby in case the test does turn out to be positive.
