The Hazards of Roofing Tar
Roofing tar is something that roofers have to work with at some point. However, this material is hazardous and can present you with some dangerous working conditions. Here are a few hazards that are associated with roofing tar.
Hazardous Fumes
Working around roofing tar can put you in close proximity to hazardous fumes. The fumes that are emitted from roofing tar are poisonous and should not be ingested. Therefore, when working around roofing tar, make sure that you try not to inhale any of the fumes.
Hot Tar Burns
One of the most common problems with roofing tar is that it can burn you severely. Roofing tar needs to be very hot in order to apply it to the roof. Therefore, many workers that handle roofing tar have been burned severely at some point. When working around roofing tar you want to make sure that you have protective layers on to prevent severe burns.
Slips and Falls
Another problem with roofing tar is that it can be very slippery. Many people have accidentally stepped on to roofing tar and find themselves falling down. When this happens, you could potentially slide right off of a rooftop. This could lead to significant injuries as well as potentially killing you. Therefore, you need to exercise caution when walking around roofing tar.
