The Pros and Cons of Laminate Flooring
Laminate flooring is a fairly new and increasingly popular option for flooring. It is by far the fastest growing in the floor industry. It has only been around for about twenty years. Laminate flooring has a number of advantages and disadvantages. The main reason for its popularity is that it provides the perfect compromise between traditional wooden flooring and other types of flooring, such as carpet or vinyl. There are still some important disadvantages which you should consider before choosing laminated flooring for your home.
Knowing Exactly what Laminate Flooring Is
Many people assume that laminate flooring is a real hardwood veneer on a fiberboard base. However, this is not the case. The base used in laminated flooring is made from a high density fiberboard. A photographic image is printed on the type of paper over the surface. This image often gives the impression of a real type of wood. However, it is not. You can also get laminated flooring which simulates marble, terracotta and other types. It is a common misconception that laminate flooring only has a wood effect as it often does when it is displayed in advertisements. Laminated flooring is available for many different scenarios. You may choose to have laminated flooring in a utility room or a kitchen.
Cost Effectiveness
One of the main reasons that people use laminate flooring, rather than traditional wood flooring or parquet flooring, is because of it's affordability. Laminated flooring is durable and attractive, yet it does not come at the high price tag of many other types of flooring.
Low Maintenance
Laminated flooring also requires little maintenance. To protect the surface, it is sealed with a long lasting coating. It is much more resistant to water, staining and scratches than traditional wooden floors. It requires very little maintenance, and can be washed in the same manner that you would wash a tiled surface. Maintaining them is very easy, and they last a very long time. This is especially the case if you go for higher quality laminate floors.
Easy to Install
Laminated flooring typically comes in the easy-to-install tongue and groove type. The laminated flooring is simply applied to the sub floor with each plank fitting into the previous one. They are cut to size when required. Installing a laminated floor in an average sized room typically only takes a few hours. This assumes that the surface is already prepared appropriately.
Disadvantages of Laminate Flooring
The only real disadvantage of laminate flooring is that it cannot compete with a traditional hardwood floor in terms of appearance, no matter how high quality it is. Laminate flooring is still completely artificial, and it is not suitable in many period homes. Your individual circumstances will dictate whether or not laminate flooring is appropriate for your home. In many cases however, laminate flooring is a great alternative to the other methods. It provides you with increased durability, less maintenance and a less expensive price tag.
