The Uniform Mechanical Code Explained The Uniform Mechanical Code Explained
The Uniform Mechanical Code is a suggested national standard that individual states can choose whether or not they want to adopt. The code was developed to ensure that all mechanical systems are installed correctly. The mechanical systems that the uniform mechanical code applies to are combustion, refrigeration and HVAC (Heating Ventilation, Air Conditioning).
The purpose of the Uniform Mechanical Code (UMC) is to provide the public with a method of safely installing mechanical systems. There is also plenty of movement in the mechanical code which will allow new improvements and advancements. The UMC is revamped every three years, information about the code is available at the IAPMO, International Association of Plumbing and Mechanical Official, web site.
What the Uniform Mechanical Code Covers
The uniform mechanical code is a very wide reaching mechanical code which controls the installation and location of many systems. These include the installation of boilers, gas pipes, solar power panels, generators, ducting, exhaust gas systems, ventilation and heating systems.
The mechanical codes will be slightly different in every state. It's important that you find out about the specific mechanical codes that apply to your state. There are a number of different ways to do this including searching on the Internet, or visiting your local library. If all else fails you can talk to a respected plumber, or professional installer, to get the answers to your questions.
Purpose of the Uniform Mechanical Code
The whole purpose of the universal mechanical code is to protect the safety of the public when the mechanical devices are installed. Mechanical systems can be very dangerous, if fitted incorrectly. The code is designed as a way of regulating this and ensuring that everyone complies. The universal mechanical code may seem annoying at times however it's all designed to help you.
Basics of the UMC
The UMC is huge document which is overhauled every three years. The document is split into a number of different sections. This document can be viewed from the IAPMO web site, or by searching for it on the Internet. There is also a wide range of books designed to help you to understand the contents of the UMC. There are also a few web sites which aim to tell people about the basics of the UMC.
When to Read the UMC
The Uniform Mechanical code applies to lots of separate pieces of equipment which is why it should be read when doing a wide range of different projects. If you are installing air conditioning or heating systems then the code should be read and listened to. The UMC also states information about gas pipes, and waste venting. Lots of different types of systems are covered in the code. By sticking to the code you should be able to make the success of the project much more likely and also reduce the risk of any danger.
