Three Tips for Choosing Brick Pool Coping
Brick pool coping is the area immediately around the pool space in your yard or property. The coping is an important feature of the pool for several reasons. In the first place, coping helps to protect the pool from outside contamination and to protect the rest of the property from the pool's water. It must be sturdy, thick and durable. Additionally, however, pool coping is an aesthetic choice that you can use to enhance the natural appearance of the pool and to help to integrate it fully with the surrounding area. Therefore, it's important when you're selecting brick pool coping that you find a material that will work for both of these tasks sufficiently and to your aims and desires. Read on for some tips on selecting brick pool coping.
1. Keep the Protective Aspect in Mind
Pool coping should be not only a good way to provide a space around your pool to walk on and lay on, but also a secure and waterproof boundary to ensure that the water from the pool doesn't leak into other parts of your property. Look for bricks with a high density and grout that has excellent water resistance and waterproofing. You should also plan to look for materials in general that will help to protect the pool against exposure damage; items that have a history of cracking or breaking in extreme temperatures and weather situations are a poor choice for your pool coping.
2. Consider the Aesthetic
What is the color of the pool tile? Many people try to integrate the color of the coping with the color of the pool tile in order to make a cohesive and coordinated aesthetic for their area. Obviously, most pool tiles are not red brick, but this doesn't mean that you can't find other types of tile or brick coping that will match in a better way. Alternately, you may wish to match the brick with the brick in your house, if it is made of bricks. This can be a nice way to tie in the outdoor space on your property with the home itself. Finally, think of how you'll plan to create a unique visual pattern with the bricks, or if you'd prefer to simply lay the bricks and have them serve more of a functional purpose than an aesthetic one.
3. Shop Around
Brick pool coping can be expensive. As with any other facet of pool installation, the products are available only in large quantities, and the process of buying and installing them can be very expensive. Therefore, in order to have the best deal that is available to you, you should take the time and effort to research your options online. This will not only give you a better sense for how many different types of coping materials you'll have to choose from, but it will also help you to find the best deal that's available, whether it's online or at a local store.
