Tips for Adjusting the Tension on Garage Door Springs
Garage door springs need to be tightened frequently or they may loose their efficiency. Instead of waiting for the later, it is important to tighten them promptly. The basic guidelines to assist a person in this activity include:
1 - Information
Gathering information about the operations of the system. This will help in identifying when it is loose and it requires tightening. It will also be easy to notice any cases of worn out garage door springs.
2 - Assembly
All the equipment needed should be assembled because this work is quite involving. This will save time instead of moving around looking for the equipment. In addition, working with the entrance open is easier. However, it can be risky incase it comes back down. A weight can be placed under with the entrance half open. This will ease the amount of tension on the coils and reduce the amount of effort required in tightening them.
3 - Assistance
Help is also necessary because the entrance is heavy. A person should look for assistance that will come in handy when working with the entrance open.
4 - Safety
For safety reasons, movement through the entrance should be restricted because the coils might snap loose. It is also important to avoid working under the entrance when it is fully open.
