Tips for Caring for Rubber Flooring Tips for Caring for Rubber Flooring
Rubber flooring is attractive because of many reasons. It is environmentally friendly and is a recyclable product. It is also available in many different colors and patterns. You can even purchase rubber flooring that imitates the look of other materials, such as stone. One of the biggest positive points about rubber flooring is that it is easy to maintain. The tips listed below will show you how to properly care for your rubber flooring so that it will last for ages.
Seal New Rubber Floors
All rubber floors require a coating of sealant to prevent dirt accumulation and damage to the floor. Follow manufacturer recommendations on the sealant and the process of sealing.
Keep Door Mats at All Entrances
To prevent dirt and grit from travelling indoors, you can place door mats at all the entrance points. Avoid the use of outdoor footwear, high heeled shoes and heavy boots if possible. This is not applicable for public areas such as gymnasiums, where the rubber flooring is built to withstand such stress.
Wipe Off Grease Spills Immediately
Grease can leave permanent stains on rubber flooring. Use a solvent to clean the grease stains and rinse it off immediately. Never let the solvent sit on the rubber floor, as it will cause damage.
Sweep the Floor Daily
Remove dirt and dust on a daily basis with the use of a vacuum cleaner or a brush. This will prevent a lot of damage that can be caused by fine dirt particles, stones and grit.
Use an Auto Scrubber to Remove Dirt
Use an auto scrubber with a microfiber pad for the purpose of cleaning stubborn dirt buildup. The microfiber is useful for trapping dirt in corners and depressions.
Avoid the Use of Strong Cleaners
Strong detergents and cleaners can cause permanent damage to rubber flooring by reacting with the material. Use mild cleaners recommended by the manufacturer. Other good choices are all purpose cleaners and fabric softeners, which you can dilute and apply on the floor. Always test these products in an inconspicuous area before applying them everywhere.
Use a Wax Stripper to Remove Buildup
Once in a while, you will have to remove wax buildup with the use of a stripper. Follow manufacturer recommendations on the purchase and use of stripper.
Wax Rubber Floor as Needed
To wax a rubber floor, you can apply a thin coat of wax and let it dry. Then, follow up again with another coat of wax. Avoid excessive application of sealant or wax because it will peel and crack apart.
Avoid Water Accumulation
Never let water sit on the rubber floor for too long because it will make the floor slippery. The water can also damage the effectiveness of the flooring adhesive, and the floor may come apart.
Never Use Abrasive Cleaners
Never use steel wool, scouring pads, or abrasive cleaning agents or materials on the rubber floor. Such items can leave permanent marks and can also cause discoloration and staining of the floor.
