Tips for Cleaning an Acrylic Solid Surface
It is important to regularly clean an acrylic solid surface to ensure that it remains smooth and visually appealing. If you have acrylic countertops in your kitchen, here are a few tips to help you keep them clean.
Tip 1 - Never Use Abrasives
When cleaning an acrylic solid surface it is important to steer clear of any abrasive cleaners or materials. These can cause scratching or deterioration. Use a soft rag or sponge when wiping down the countertop and keep from applying too much pressure.
Tip 2 - Use an Acrylic Specific Cleaner
There are many cleaners that are made specifically for acrylic surfaces. It is important that you read the cleaning supplies to ensure that it is appropriate for this material before you purchase or use it. Acetone is one chemical, for example, that you want to avoid. When installing the countertops, check with the supplier or store to find an approved cleaner for that specific material.
Tip 3 - Avoid Soap Build Up
One thing that you want to absolutely avoid, is leaving soap on or near your acrylic countertops. If you store your dish or hand soap next to the sink, be sure that you have a mat or dish to keep the soap from forming a residue on the acrylic. Also, when cleaning make sure to keep rinsing to avoid any soap or cleaner from pooling and forming spots.
