Tips for Creating Decorative Concrete Floors
For those who are considering decorative concrete floors as a way of renovating interior spaces, some basic guidelines apply to creating great surfaces with different kinds of concrete. Concrete floors are popular with some homeowners who want durable flooring with attractive colors and patterns. There are many ways to go about this kind of project, but keeping some handy tips in mind will help to guide the process.
Get the Subfloor Right
When it’s time to add an additional layer to a floor, it’s best to think about the underlying surfaces and how they will interact with the additional layers for a final result. For instance, some experts do not recommend putting concrete over plywood subfloor, where they may give the green light to covering these subfloors with cement. Generally, home improvement do-it-yourselfers will be looking at adding layers to subfloors in a manner that provides the right amount of flexibility to avoid cracking or other problems.
Learn About Staining
Staining concrete floors can be an effective way to get different color schemes into your decorative floor pattern: creative staining can add some eye-popping hues that fit almost any interior style. However, to get the best results, you’ll need to know about the best applications for each kind of stain or seal. Take a look at various sealing options and the way they compliment a concrete floor installation.
Choose a Texture
In the general array of possible concrete flooring projects, several different surface textures change the result. A swept texture or other rough texture may be fine for some spaces, but not right for others. You’ll also want to look at how embedding different kinds of aggregate material changes the texture of the floor surface. There’s also the option of stamped concrete, where builders put patterns into the surface for a more even look.
Find Out About the Aggregate Slab Process
Aggregate slab is all the rage with many contractors who are using it to build floors and even other surfaces like countertops. Aggregate slab creation includes putting a large amount of concrete around various materials like glass panels, large pebbles, or anything else that can show up evenly on a concrete type surface for an appealing decorative presentation. Assess choices for these kinds of multi-material processes and pick those that will make your floors look good.
Evaluate Cost
Each kind of decorative concrete floor has its own costs involved in manufacturing and installation. One cost factor is materials that may be pricy, and other costs relate to the time and energy that it takes to pour, set or otherwise create decorative slabs. Get detailed price quotes on projects and see if concrete slabs fit your overall budget or if there are ways to modify the plan to cut costs.
All of the above can help property owners brainstorm ways to add decorative concrete floors to their buildings.
