Tips for Cutting Metal Corrugated Roofing and Siding Tips for Cutting Metal Corrugated Roofing and Siding
Corrugated roofing is a popular choice that provides durability and weather resistance for homeowners. The metal must be cut correctly for an effective installation.
The Right Tools
To create precisely cut panels, you will need power shears. Be sure you also have protective eye wear and work gloves to wear while you are working.
Preparing Your Work Surface
You will need a strong level surface to place the metal to be cut. This surface will keep any metal sheets from sliding and causing damage or injury. The area should also be well lit so that you can see where to make your precise cuts.
Determining the Measurements
Use your measuring tape to determine the size of the panel you want to cut from the metal sheet.
Marking the Corrugated Metal
Use your marker to mark the correct sized panel you need. Use your square to ensure that the sides are straight.
Cutting the Corrugated Metal
Put on your protective eye wear and work gloves before you begin. These will protect your eye sight and protect your hands from any cuts from the sharp metal. Use your power shears to slowly and carefully cut the panel from the metal sheet. Guide the shears along the lines you have marked.
