Tips for Driving a Rear-Wheel Drive Car in Snow
A rear-wheel drive car is often a wise choice when it comes to purchasing a vehicle. It's sturdy and better at accelerating, stopping and overall control. However, there is one area in which it fails over other vehicles and that's driving in snowy or icy conditions.
Why the RWD Car Performs Poorly in Slippery Conditions
A rear-wheel drive car is propelled by the rear wheels. This usually works to a driver's advantage. However, when the ground is slippery, the vehicle struggles to gain traction because the weight of the engine is located in the front, not over the tires providing power.
Drive Slowly
The most important tip when driving any car in the snow is to drive slowly and carefully. Make turns very slowly to decrease your risk of slipping.
Put Weight in the Trunk
You can correct some of the weight imbalance by loading the trunk of the car with heavy bags of sand or cat litter. Having these on hand will also help if you get stuck in a snow bank and need to throw down the sand or litter to gain traction.
Know What to Do When Sliding
If you do find yourself slipping, stop accelerating. Turn the steering wheel gently in the direction you want the car to wind up. If you have anti-lock brakes, slowly and firmly put continuous pressure on the brakes. If you don't have anti-lock breaks, pump the brake continuously until you stop.
