Tips for Filling Rotted Wood Tips for Filling Rotted Wood
Nobody wants to come across any type of rotted wood but this situation is made worse when the wood is used for something important like doors and floors. You can replace the rotted wood but you can also repair it by filling the rotted areas. This isn't a job that is hard to do but there are some things to keep in mind when trying to fill rotted wood. Failure to do so can cause the problem to become much worse. The article that follows will share with you several tips on how to properly fill rotted wood.
Check the Depth
Rotted wood can become very dangerous over time. If the wood in your floor is rotting it is essentially unstable and walking over it can cause it to collapse. Countertops, tables and other structures of this type are not overly dangerous when you find bits of rotted wood. A door that is rotting can be a security risk and anything that requires stability is also dangerous. Use a ruler and insert it in the rotted wood. If it goes in further than an inch or penetrates the other side then you may be better off replacing the wood. It is a good idea to fill areas of rotted wood when pieces of the original wood remain for the filler to adhere to.
Remove Rotten Wood
When you discover holes in the wood that is rotting you need to remove all of the wood that is rotted. You can use your fingers, a screwdriver or hammer depending on the size of the area. You want to remove as much of the dead wood as possible to start with as much sturdy wood as possible.
Epoxy Filling
There are many types of fillings available on the market for you to choose from when filling spots of rotted wood. One of the more favorable fillings is epoxy. This filling is liquid plastic and hardens as it dries. It will adhere to most anything you use it on including wood. Epoxy does not expand as it dries but it is hard to sand down flush so you have to be careful when you are using it so it does not overflow. If it does then you will have to quickly scrape it off the wood and smooth it out with a damp cloth. Epoxy is best used on a surface of rotted wood that is not hanging, like a door, as the epoxy can ooze out.
Wood Putty
This is the second most used type of filling for rotted wood. The wood putty is yellowish which makes it very noticeable in high profile areas. It is stiff enough to use in doors, on frames and the like without worrying about it oozing from the wood. The wood putty also does not expand but it is easily sanded to a flat surface that is flush to the wood once it is dry. The wood putty can be dyed and even stained which makes it great for doors, tables and floors.
