Tips for Identifying Dry Rot in Car Tires
If you suspect that your vehicle's tires have fallen victim to dry rot, it's important to familiarize yourself with the telltale signs. Below are two tips for properly identifying dry rot on your tires.
Tip 1 - Thoroughly Inspect Your Sidewalls
One of the best ways to identify dry rot on tires is to give the sidewalls a good once-over. If you come across a series of cracks, whether large or small, you may be dealing with dry rot. Lone cracks are not necessarily an indication of dry rot, unless the crack is exceptionally deep. Should you notice any discoloration while inspecting the sidewalls, particularly if it is located in the immediate vicinity of any cracks, you most likely have rot on your hands.
Tip 2 - Check Your Treads for Irregularities
Discrepancies in your tire treads are another indication that rot has developed. In much the same fashion as your sidewall inspection, take care to check your treads for any deep cracks or discoloration. Any large cracks in your tire treads, even lone ones, are often indicative of rot. In order to inspect the entirety of your treads, turn the steering wheel as far right or as far left as it will go. Shut off your car and proceed to look over your tires.
