Tips for Installing a Metal Lath in Stucco Tips for Installing a Metal Lath in Stucco
Attaching metal lath can be a tricky job, especially if you have never done it before. If you find yourself with this project, here are a few things that you can keep in mind:
Tip 1 - Use the Right Tools
It is important for this task that you are using the appropriate tools and materials. Shears can help you to cut and shape the metal lath and be sure that you have a measuring tape so that you are making accurate sizes. A circular saw can also help you with the cutting if need be.
Tip 2 - Leave a Gap
Leaving a gap between the surface of the wall and the metal lath is important to a secure attachment. Typically this gap needs to be about a quarter of an inch. You also want to be sure that you are wire tying at certain intervals. A 9-inch interval is a good place to start and then you can modify from there if need be.
Step 3 - Use Right Size Nails
Using the correct size nails is important to be sure that your metal lath is actually secured in the stucco. You will want to use nails that are at least an inch, almost 2. An inch and a half typically works well and ensures a secure attachment.
