Tips for Installing Blinds for Bay Windows
When measuring, ordering and installing blinds for bay windows, there are a few things you can do to make the job easier. Consider the following as you plan and execute this project.
Measuring
When measuring blinds for bay window, you must be careful. Bay windows are at an angle, so you have to take that factor into account. The best method is to measure the width of the window, and then mark the midpoint. That way you will not go wrong. Secondly, it is best to measure the width of each window, and then add up some extra inches on either side. This will help to reduce the probability of the sun's rays from entering the room from the edges. Make sure that you pay attention that the blinds will not intersect each other, so consider the space that there is between one window and the other.
Levelling
Use a levelling tool so as to make sure that you are going to install the blinds linearly and neatly. Use it to check after fixing each and every bracket.
Installing
Install the brackets, and snap in the rails of one window at a time. Each time, check and make sure that once the blinds are fixed there will not be one interfering with the blinds of the window next to it. The best way to avoid this is to hang the blinds inside the window's casing.
