Installing hidden overlay hinges can be difficult if you are unfamiliar with the process. This is why it is a good idea to get the facts and understand a few tips and tricks so that you can put up the overlay hinges done easier and faster.
Mounting Order
It is important that you know the order in which you should mount all of the hinges. Mounting them in the correct order will allow you to be able to complete the job a lot easier. It is a good idea for you to start the hinges at the top and work your way down when mounting overlays.
Type of Overlay Hinges
There is more than one type of overlay hinge. There is a ½-inch overlay, as well as a full overlay. The ½-inch will be needed whenever you are working with a door that is 1 inch larger than the opening. The full overlays will be required when you have door covers that have 1/8-inch of the face plate showing.
Measure Door
Measure the door from the top and the bottom. Make sure that you measure where the hinges will need to be installed.
