Tips for Installing Metal Window Flashing Tips for Installing Metal Window Flashing
When installing metal window flashing, there are a few things that you will want to keep in mind. Here is a quick guide of tips that can help you through your next project:
Tip 1 - Measure Carefully
You will need to measure the outside of the window carefully. Keep in mind when you are measuring that the inside and outside will not be the same size because of the 45-degree angles of the corners. Be sure that you measure for the biggest side and it you have to cut more off at the end then it is much better then having to redo it or not having enough.
Tip 2 - Use a Straight Edge
Do not just eye ball or free hand the measurements or markings that you make. Be sure that you are using a measuring tape as well as a straight edge to get everything lined up properly. This is especially important because installing metal window flashing improperly can cause more damage than not installing it at all.
Tip 3 - Clean the Area
It sounds silly, but cleaning the area before you begin installing is important. Be sure that you get all of the dust and debris out of the way so that you don't experience build up later.
