Tips for Installing Preformed Concrete Steps Tips for Installing Preformed Concrete Steps
Preformed concrete steps are very easy to install. These heavy steps are made at masonry companies. The preformed steps take all the labor out of doing it the old fashion way, which was to form the steps and pour the concrete. These steps are now kept in stock at masonry warehouses. But when working with these steps, you will require a crane for placement.
Check Size and Space
The steps themselves have standard measurements and sizes and are also manufactured customized to meet your needs. If you are buying standard steps, then check the space size available at your home where you wish to install it. If the standard size is too small or big for you, you can ask the manufacturer to customize it for you. They come in a variety of colors and finishes depending on your preference. You may be able to come up with ideas of your own and have the concrete company work them out. You may be able to make a deal to have them specially made for you.
Gather all Tools
If you plan the project carefully, you will be done with it smoothly. And the first step of planning to get all tools. Before starting the project, it is best to gather all tools required to finish the task. You may require things such as epoxy concentrate adhesive, trowel, trough, rebar, drill, crane, concrete etc.
When to Hire a Specialist
If you have a back problem and are not allowed to carry heavy weight or you are not comfortable with heavy equipment, then it best to ask for an installation specialist. To have the steps installed requires the work of a construction crew and a crane. They will come out and do all the necessary work for you. It would be a little hard for you to do it unless you have your own construction crew to help. Don’t forget these steps are made out of concrete so you won’t be able to just pick them up and set them down. Unless you are very experienced they may need to be professionally installed. It is not too expensive. If you are on a tight budget, you can still afford to have your stairs replaced at a minimal cost.
Now that you have looked at the availability and installation of the steps, you may be thinking it is time to add some new steps out to the patio or into the garage. These steps are sturdy and will last a lifetime. They are hollow, but still heavy, so no one will move them at all. They are steps that will help to make your house look better. There is no better way to get these steps than to have them delivered to you and set up. These are better than wooden steps that may end up rotting out in the long run and then replacement is required. With the concrete steps, there would be no rebuilding necessary. These stairs make great replacements for wooden and steel stairs.
