Tips for Laying Brick Pavers
Laying brick pavers is a job that can transform the look of any space. When you are about to take on this job, there are several things that you will want to keep in mind. Here are a few tips for laying brick pavers effectively.
Buy Enough For the Job
Many people try to skimp on the amount of brick pavers that they purchase initially. In most cases, you will want to buy extra brick pavers when you make your initial purchase. If you end up short on the job, you are going to have to go back and try to find brick pavers from the same batch. In many cases, this can be next to impossible. Therefore, you will want to make sure that you buy plenty of brick pavers to cover the space that you want to cover. When you are measuring the space, you will want to calculate the square footage of the area and then add approximately 10 percent to that number. This is going to provide you with enough material for the job in most cases.
Base
When you are about to start the job, you want to spend a lot of time preparing the base. You need to start out by digging out the area in which you are going to lay the brick pavers. Make sure that the area that you dig out is completely level. You are going to want to put about 6 or 7 inches of stones in the hole as a base before pouring the sand and putting on the pavers. Therefore, you will want to make sure that you dig the hole deep enough so that you can account for this depth. Once you have a hole deep enough, you need to pour it full of stones about 6 to 7 inches deep. Then put 1 to 2 inches of fine sand on top of the rocks. You are then going to want to take your time to smooth out the sand. You can use a board and a level to smooth out the sand and make sure that it is smooth.
Planning
When you are ready to start laying the brick pavers, you may want to take some time to plan out how you are going to lay them in the space. Take a piece of paper and a pencil and draw a detailed diagram of the area with dimensions. Then you are going to want to draw in the pattern for the brick pavers on your paper. You will also want to take note of any areas that you are going to have to work around. For example, you may need to calculate where a barbecue pit is located in the area so that you can account for it in your pattern. By spending a few minutes laying out how you are going to lay out the brick pavers, you are going to be able to save yourself hours later.
