Tips for Maintaining a Fireclay Sink Tips for Maintaining a Fireclay Sink
If you are looking for ways that you can maintain your fireclay sink then there are a few different things that you can do. Maintaining a fireclay sink will help to keep it lasting for a long time to come. It will also help to make it look nice and also strong.
Clean
The most important thing that you can for your fireclay sink is to keep it clean. Make sure that you take the time to clean it properly as well. The best way to do this is to fill up your sink with hot water and liquid soap and scrub it with a soft sponge. You may need to use baking soda for any tough spots.
Rinse Regularly
The best way for you to keep your fireclay sink looking its best is to rinse it thoroughly after you have used it. This will help you to not have to worry about build up as often.
Overuse
Make sure that you do not use your fireclay sink too much or attempt to clean things that are overly dirty in it. This can end up causing your sink to become dull and difficult to clean or fix.
