Tips for Preventing Blocked Drains
If blocked drains are a frequent problem in your bathroom, you'll be pleased to learn that there are several easy tips for avoiding them altogether. After utilizing the following tips, your drains will be clear and clog-free.
Perform Regular Hot Water Rinsings
One of the easiest tips for preventing blocked drains is to carry out regular hot water rinsings. With the aid of your faucets, run a steady stream of hot water down your sink and bathtub drains on a weekly basis. This will help wash away any caked-on hairs, as well as other forms of drain-based debris, before they're able to build up and form clogs.
Use a Drain Protector
If hair clogs are among the most common causes of blocked drains in your bathroom, a drain protector can work wonders for you. When placed over your drain, these handy devices will catch the vast majority of wayward hair before it has a chance to find its way into your drain. For best results, take care to clean your drain protector after every shower.
Promptly Plunge Slow Drains
Another good way to combat blocked drains is to plunge a drain the instant it begins to function more slowly than usual. This will quickly restore your drain to its normal speed and effectively purge small clogs before they have a chance to grow larger.
