Tips for Spacing Light Fixtures in a Recessed Ceiling
When it comes to working with recessed ceiling lights, there are a few things you will want to keep in mind. This type of lighting looks amazing in many rooms and is a great asset as long as you know how to space it properly. Here are a few tips that can help you space the light fixtures in your recessed ceiling.
Tip 1 — Using Limited Space
If you are working in an area that has limited space, use fewer light fixtures of a higher wattage and space them out widely. This way, you can still have a bright room without having to overload on lighting.
Tip 2 — Rule of Thumb
One great rule of thumb is to place the light fixtures about 6 to 8 feet away from each other. This is the perfect distance — not too close, not too far. The most important part is to make sure that they are installed evenly; they need to be lined up right.
Tip 3 — Measure the Room
Do not go into this project blindly. Make sure to measure the room before doing all that work. This will allow you to plan the locations of your lighting fixtures properly.
