Tips for Trolling Deep Water with Success Tips for Trolling Deep Water with Success
Trolling deep water fishing techniques depend on what you want to catch. As with all other types of fishing, deep water fishing has some standard methods and techniques that are likely not to fail you if you follow them closely. There are some tips that will help you land the fish of your choice, while you are on a deep water fishing trip. However, each fisherman sets his own goals. Therefore you also need to decide what you are after. You should decide in advance whether you want to catch an albacore, a sea bass or a yellowtail, because each one of them might require even more specific techniques and approach. Here are some tips for you that will make deep water trolling a much more fun and rewarding experience for you.
Trolling for Albacore Tuna
One of the most popular fish to catch is the albacore tuna, which can be found in deep waters all over the world. You can distinguish it from other types of tuna because it has an elongated pectoral fin. This type of tuna is caught by trolling through areas with mild temperatures and prime diet conditions for the albacore. You will need to hire a boat with trolling rigs specifically for tuna, but you can also use your own rod, provided that it is between 5.5 – 6.5 and 60 pounds approximately.
Using Jigs
It is recommended that you use colorful feather jigs because experience shows that it is an effective trolling technique. You can also use bait, but in this case you should opt for sardines or anchovies. If using a boat, you should make sure that the line is straight, in order to prevent tangling. In most cases, when trolling for albacore you should keep in mind that the first baits are usually bit. Therefore you need to be cautious from the first moment you start fishing.
Trolling for Yellowtail
Yellowtail is mostly found in deep tropical waters. Trolling and jig fishing are the most common methods in catching this type of fish. Yellowtail is very fast, so you need to be prepared to combine fishing methods as well. You can take some lures and baits with you, with sardines and anchovies, but you should also consider jig fishing because you can fish with a heavier line. You should consider having 40 to 50 pound-test as well. You will probably need to use surface iron as well, especially when yellowtails feed near the water surface.
Trolling Speed
Regardless of what you are trolling for you should never troll at the same speed constantly, because fish might follow you but they will also be cautious enough to see if the fish has detected them. Change the speed, either slowing down or speeding up and you will be probably surprised to see that a larger amount of fish will be caught. When speeding up, you should check if the inside lines pick up any fish because you need to know if you have enough line out. Usually when the outside line is shallow, the inside is deeper.
