Tips to Fill Your Dumpster Rental Efficiently
rent a dumpster
Whether you are doing major home renovations or are moving a large number of items out of your home that you plant to dispose of, you may need a dumpster rental. Renting a dumpster will allow you to remove a large number of unwanted items from your home quickly and efficiently without having to take too many trips to the dump.
Renting the Dumpster
When you call to rent the dumpster, it is important for you to find out how it is rented. Is it rented per day, week, etcetera? Doing will help you know how much time you will have with the dumpster and can a plan for filling it. Have everything ready for the dumpster before it arrives to save time and money.
Filling the Dumpster
When you are filling the dumpster, it is important to break things down as much as you can. Put bulkier items at the bottom. Place trash around them to fill in any extra space. If you are getting rid of cardboard, foam, or small flat items, you can place them at the bottom of the dumpster as they will break down and will not cost much extra room. Fill any empty areas in furniture or other items that you are discarding with other garbage or discarded items. By following these tips, you could save yourself a lot of time, money, and space.
