How to Remove a Toilet
Rubber gloves
Plunger
Sponge
Wrench
Rags
If you're thinking about changing the look of your toilet, you will first need to learn about toilet removal. Replacing your toilet is a great start to changing the look of your bathroom, and it's not a project that needs to be left to a professional. You can easily finish this project by yourself with the help of a friend. In the steps below, you will find how to remove your old toilet with ease so that replacing it is just as simple.
Step 1 - Turn the Water Off
Turn the water off. Make sure the water at the supply lines is turned off all the way before moving onto the next step.
Step 2 - Let the Water Out
Remove all water from the bowl and the tank before you remove any part of the toilet. Do so by flushing the toilet multiple times until the water is gone. To avoid overflow, you may want to manually operate the flapper valve.
Step 3 - Make Sure It's All Gone
Using a plunger, plunge excess water down. Using a rubber gloved hand, use a sponge to remove any remaining water from the tank and bowl.
Step 4 - Working Inside
Remove the supply line from the fill valve inside the tank.
Step 5 - Detach the Tank From the Bowl
Detach the tank from the bowl by removing the wing nuts which connect them. After removing the wing nuts, you can simply lift the tank off the bowl and move it out of the way.
Step 6 - Remove the Caps
Locate the caps on the base of the toilet and remove them. Doing so will unveil the bolts that connect the bowl to the flange in the floor. Remove the bolts. If corrosion is present, there are a couple of things you can use to make it easier to remove. Use a lubricant such as WD-40 to aid in removing it. Another way is to cut or grind the nuts.
Step 7 - Break the Caulk Seal
Use a utility knife to cut along the edging of the caulk at the base of the toilet.
Step 8 - Lift
Simply lift the bowl, rocking it back and forth and breaking it free from any sealant that may be left.
Step 9 - Preventing Odor
Stuff rags into the existing hole from where you removed the bowl to prevent sewer gas from leaking into the area where you are working.
Step 10 - You're Ready to Replace
That's it. The old bowl is gone, and it's ready for some change. Replace your new toilet and give yourself a hand.
