Toilet Runs Every 5-10 Minutes for 30 Seconds
A toilet that runs every 5-10 minutes is a common bathroom issue which can be annoying to encounter. Apart from constantly hearing the sound, it can cause your water bills to rise due to wasted water. Fortunately, fixing this issue isn’t too tricky and can be done by most people with just a few tools. Here are some of the most common causes and ways to fix them.
Bad Flapper
A damaged or outdated flapper might be the number one culprit for a toilet running every 5-10 minutes. Over time, the water, combined with the chlorine products, deteriorates the toilet moving parts, causing your toilet to leak, even if it is not in use.
The toilet tank flapper is a simple toilet part, a seal made of rubber, flexible and durable enough to navigate the flush valve that holds on the water in the cistern, but also vulnerable to disintegration and leaks, explains Stephany Smith from My Plumber.
Jake Romano from John The Plumber has one method of figuring out whether the flapper has gone bad. Mark the tank’s water level, or measure it with a ruler and shut off the water valve beside the toilet. Wait an hour and then check it. If the water level has gone down to the flapper, this indicates you will need to replace the flapper. Flapper valves usually need to be replaced after damage or a few years of age.
Even if your flapper is a water-resistant device, there’s one thing that you can do to make your part withstand the test of time. Smith suggests refraining from adding chlorine-based cleaners to the toilet tank.
Pick Up a Replacement Flapper on Amazon
Long Or Stuck Flapper Chain
Often, a short or stuck flapper chain can make it impossible for the rubber seal to flush correctly. You’ll know this if you feel tension when you push the handle. One simple readjustment by hand can make your flapper-chain combo do its job.
During other times, the flapper chain maybe just too long. When the chain is long, it will get stuck between the flush valve and the flapper. As a result, water leaks occur because the flapper doesn’t seal correctly. To fix this issue you can simply buy a new flapper chain and replace it with the old one.
Too Much Water Pressure
Your toilet tank components are delicate and designed to open and close the fill valve at normal water pressure ranges.
Smith says, “If the residential water pressure is excessive - over 70-80 psi to be specific, your toilet tank may be running intermittently.”
Over time, toilets and the other home appliances under stress from excessive pressure are likely to form cracks, or the flapper rubber seal can break, causing the water tank to run frequently, she adds.
If your pressure gauge dial indicator has been giving high-pressure readings regularly, you may want to install a new or check the existing domestic water pressure regulator.
Bad Fill Valve
If your tank isn’t leaking, but the toilet keeps running, you need to replace the fill valve. Bad fill valves are known for causing issues with toilets.
“Toilet fill valves, or ballcocks, control the water filling in the tank,” says Romano. “They float as the water rises, which shuts the valve.”
Fill valves can also cause a toilet to leak continuously. Romano explains if you flush the toilet and lift the float arm or fill valve, the water should stop. If the water doesn't stop, it means that it's leaking.
You should replace the fill valve every five years. You can find a replacement kit in just about any hardware store, and they come with all components needed for it.
