Top 5 Energy Efficient Siding Materials
Getting the right insulation and siding is critically important for maintaining an energy-efficient property. An energy efficient home can contribute to better energy conservation and help save money. This is especially important when many communities struggle to meet their energy needs. Experts agree that the outer layers of the siding material rarely make the difference in energy efficiency. Most of the R value, a standard measure of energy efficiency , is determined by the kinds of interior insulating materials that are installed with the siding. Choosing the right insulators can help improve the ability of the building to contain energy and limit heating and cooling bills.
Polyurethane foam
Polyurethane foam is a type of insulation material that is common in some kinds of properties. It has an estimated R value of around 6.25 which makes it an excellent material for insulation because it holds energy in an enclosed space.
Polystyrene or beadboard
Polystyrene is a panel insulation that has an R value of roughly 4. This kind of installation is an attractive choice for some contractors who want to blend collision with a relatively high R value for energy savings.
Fiberglass insulation
Fiberglass also has competitive R values because it is included in various insulation products, such as rolled insulation. Installing these products can be more difficult, when compared to other types of installation. Fiberglass can also cause difficulties after it is installed. Be sure that fiberglass installation is right for your particular building area before you add this type of material to your home.
Solid core vinyl
When it comes to exterior siding, a new type of vinyl called solid core vinyl carries its own competitive R rating. This type of siding is an excellent choice when you want to add an exterior siding that seals air and improves energy ratings.
Other exterior choices
Aside from materials like the ones mentioned above, energy efficiency experts also to look at the thickness of walls in general. Brick and other similar installations can afford more opportunities for energy-efficient siding and insulation combinations. For example, some homeowners want to pad their walls and use products like hay bales to increase the buffer between the interior wall and the outer exterior. This creates energy savings and better overall efficiency.
The best energy-efficient home systems need to review all of the possible combinations for exterior and interior layers in order to evaluate how these items will seal in the climate controlled air that provides for comfortable living. As energy consumption becomes an important issue, governments and agencies are looking at how to promote better energy conservation in properties around the world. The range of better insulators can help ensure that energy resources are being well used.
