Top 6 Styles of Trim Molding
Trim molding, also referred to as trim boards, are a great way to form casings around doors and windows. They also cover the bottom of a wall to form base moldings. They make a room look more presentable by covering joints and other issues on the surface that you don't want to show. There are many options for trim molding. What you choose may depend on monetary factors as well as style. Here are 6 top styles of trim molding:
1. Polyurethane
This is a commonly used trim molding because it's inexpensive. If you don't want to stain and finish wood, use a polyurethane trim molding. They're easy to install with corner blocks, and lengthy one piece moldings. They won't crack when you nail them to the wall. There's no splintering, which can happen when installing some wood trim moldings. It's also a better option than wood in some cases, because it does not rot. If you live in a place where there's high humidity, you should use polyurethane trim moldings.
2. Pine Trim
This is one of the most popular trim moldings seen in many homes. It's one of the more stable styles to choose because it doesn't crack. One drawback to using pine is that the grain lines do not have a finished look. Consider painting the trim, if you're going to choose pine. The other disadvantage to using pine is that you can dent it easily.
3. Paint-Grade Trim
Paint-grade trim molding is one of the cheaper options available, which is designed to be painted instead of stained. They come in various materials, not just wood. If you buy a paint-grade trim molding that's primed, you'll only need to apply one coat of paint, instead of more, which will help to keep your costs down.
4. Hardwood
One of the top styles of trim molding continues to be hardwood trim molding. It's appealing because of its natural look, when stained and finished well. They don't crack or dent and you won't have to paint them. A simple finish will make it stand out and give a room a fresh look.
5. Softwood
If you prefer softwood, because of price, then you'll still be using one of the top trim moldings used. Stock softwood doesn't have knots, and you can stain it or leave it unstained. If you do plan to stain them, buy stain-grade softwoods. You can purchase them from a variety of materials, such as basswood or poplar.
6. Vinyl
You may be looking for a trim molding for curving walls. Flexible vinyl would make a great fit for the project. They can bend to curve around the walls for a perfect fit, which you can't do with wood. However, you cut it and install it just as you would with wood pieces.
If you decide to choose wood for your trim moldings, you'll have few problems finding what you need at your local lumberyard. Some of the vinyl and polyurethane styles may not be widely available, which means you'll have to order them online.
