Troubleshooting a Leaking Rear Wheel Cylinder
A rear wheel cylinder is something that is going to have some issues from time to time. If your rear wheel cylinder is leaking then it is important to know the reasons why and what it is that you can do to get it fixed as soon as possible. This is something that needs immediate attention to make sure that it does not get worse or cause any other issues. Pay attention to the warning signs that your rear wheel cylinder is in need of some repair or replacement.
What to Feel for
If you happen to notice that your brake pedal has a squishy or soft feeling when you press down on it then you may have some problems ahead of you. Over time, your master cylinder will begin to have brake fluids leak whenever your foot is kept on the brake, such as while you are stopped at a red light. You may find that your brake pedal goes down too far and you will have to pump the brake so that it will go back to normal. This may keep your car from being able to get a good start once again. If you begin to feel this problem then you may need to go ahead and add some brake fluid. If you find that this is not something that fixes the problem, then it is probably time for you to get the rear wheel cylinder replaced all together.
Lights
In addition to what to feel for there are also lights that will pop up on your dashboard that will tell you what you need to be doing. Look for the red brake warning to come up on your dash light. What this means is that you will need to put in some brake fluid. That or the car is trying to tell you that there is too much movement going on with your brake pedal. Remember that too much mashing on the brakes is not good for them and can over time cause quite a bit of damage. Make sure that you pay attention to what your car is trying to tell you. When a light turns on it is because there is something that needs immediate attention.
Leaks
Whenever you see any type of fluid that is leaking out of your car then you will need to pay attention to where it is coming from and what it is. If the brake fluid happens to be coming out of the master cylinder or even from the areas in the wheels then you may have a problem with the cylinders. This is where the pedal squishy softness was happening. If you see this then you should not add anymore brake fluid as it is obvious that it will not stay in the car for very long. Leaks are something that should be taken care of by professionals. If your car is leaking brake fluid from the rear wheels then you will need to get your rear wheel cylinders replaced as soon as possible.
