Tub Faucet Repair: How to Repair a Leaking Tub Faucet
New tap washer
Screwdriver
Wrench
Oil
Tub faucet repair is essential for anyone who has a leaking tub faucet. A leaking faucet can be very traumatic and stressful thanks to the continuous dripping. It's also a real waste of water which is why you must find out how to fix the leaking faucets as quickly as you possibly can. Repairing faucets isn't actually that complicated if you spend time carefully preparing yourself for the task in hand. Most people will experience a leaking faucet at one time or another. With the right preparation tub faucet repair will be very simple.
Step 1 - Switching Off the Water
You need to ensure that the water is shut off. Do this by turning either the master shutoff or the shutoff valve which is connected to the tap. You should always switch off the water whenever working with faucets or pipes. After switching the water off open the tap and allow all of the water to drain out of the pipes. This will ensure that there isn't any water left in the pipes which could end up making a mess.
Step 2 - Removing the Faucet
Now you should turn your attention to removing the handle. This is done by unscrewing the screw which is located either on the top of the handle or at the back depending on the design and type of handle. You might find that the screw has corroded and seized up, if this is the case then you will need to use oil such as WD-40 to ease the screw. Once you have removed the screw then the handle should just lift off the stem.
Step 3 - Removing the Nut
Once you have removed the handle you will be able to see the inside of the tap, here you will notice a packing nut this needs to be taken off by either using a wrench or pliers. Try to do this gently so tat you don't damage the nut itself. The stem should then come out of the tap by twisting it in the same direction you use to turn the tap on.
Step 4 - Checking the Stem
With the stem removed you will need to check the condition of it. If there is any sign of corrosion then consider replacing it. The stem should last for a long time however there is a chance that it needs to be replaced.
Step 5 - Removing the Washer
There is a screw on the stem which holds the washer in place. Remove the screw and the washer should easily come out. Even if the washer looks ok you should still replace it. Try and replace the washer with the same type because this will normally stop the leak being a problem. You will be able to purchase replacement washers at most home hardware stores.
Step 6 - Testing the Tap
Now it's a matter of reassembling the stem, nut and handle. Now check the faucet and ensure that there are no leaks.
