Inspecting Your Home for Damage to the Foundation
cracked wall
When it comes to taking care of your home, it is important to know the different types of foundation damage that you may experience. By detecting the problems that you may encounter, you can nip the problem in the bud before it becomes a serious issue and save a lot of money.
It helps to know what you should be looking for when you do a home inspection. If you keep a close eye on your home and do inspections on a regular basis, you will be able to catch many of the problems that you could face before they become costly.
Wall Bowing
Walls which bow can become a very serious problem if you do not catch them quickly. Walls usually bow before they begin to crack. Bowing is a sign of structural damage. It can also be a sign that the pressure on your home has become too high; furthermore, your foundation needs repair in order to avoid additional damage.
Structural Damage
A brick wall that has bowed is also a sign of serious structural damage. You will notice that the mortar is cracking when this type of wall starts to bow. Not only are serious repairs are necessary, but other problems may be occurring in your home.
Step Cracks
Step cracks are another type of damage to look for. When you find these in a concrete block wall, it can be a sign of pressure from the outside. Keep a watchful eye; bowing may soon follow.
Cracks in Wall
Bowing in a poured concrete wall is going to cause cracks. As soon as you notice the first crack, it is important to take care of it right away. If you don’t, it is possible that you will see another one soon after, which could be a result of the first not being repaired or another more serious problem. Keeping up on the issues as you find them prevents other problems from arising.
Cracks in House
One last thing of which to be aware is the location of cracks in the house. Everyone knows that when you purchase a new home, it may settle somewhat, but when you find cracks in the foundation of your new home, it is the sign of something serious. Even though it may seem fine in the beginning, you must know that it is also the beginning of something more dangerous in the structure of your foundation. Be sure to keep an eye on the situation.
