Understanding Sloping Walkways: Straight Slope
Walkways can be a difficult design when you are redoing your home or yard. While they seem simple, there are many different designs and styles to choose from. If you are on a slope, then a straight slope is a great idea to work with. Here are a few things to consider if you want to install a straight slope walkway.
Sloping and Drainage
One of the greatest benefits of the sloped walkway is the drainage. With a straight slope, you do not have to worry about a drainage system in the walkway as long as you have a good one at the bottom.
Designs and Styles
When it comes to the straight sloped walkway, there are several designs that you can go for. Many times people go with a straight up and down or running brick design. Since the slope is unique enough, the design doesn't have to be as out there. However you can go with a European brick design as well or another different pattern. The straight slope should be gradual as to not shock or endanger anyone.
Cost and Availability
The sloped walkway isn't expensive to install. You need to have the materials, but you can find them at any hardware store near you or online.
