Unexpected DIY Safety Hazards
DIY renovations around the house are more popular than ever. But before you start the next big DIY project, there are some safety issues you should keep in mind. Whether you plan on painting a bedroom or repairing the roof, being aware of potential hazards around the home will keep you safe no matter what project you tackle.
Saw Safety
One of the biggest safety concerns when operating a saw is kickback. Kickback is caused when the blade encounters an obstruction in the wood and can create a dangerous situation. To avoid significant injury, always be aware of the material and plan ahead for kickback. Never stand directly behind a work piece when using a table saw and always make sure chainsaw blades are in working order.
Eye Hazards
There are many projects that can create dangerous situations for the eye. Whether it’s using a spray cleaner or trimming the lawn with a weed whacker, it doesn’t take much for an airborne material to hit the eye. With that in mind, it’s always a good idea to wear eye protection even in the most unlikely circumstances.
Electricity
Working with electricity is dangerous. If you don’t take the right precautions, the electrical current in your house can leave you severely injured or worse. To avoid this deadly hazard, always make sure the power is off when performing electrical work. Avoid using electricity near water sources and never use power tools in damp environments unless they are properly grounded. You can also use a voltage meter as an added precaution to ensure there isn’t an electrical current moving through whatever device you are working on.
Ladder Hazards
Ladders are great for projects around the home. They do, however, present unique safety issues if not operated properly. Whenever you use a ladder, make sure all four legs are on level, stable surfaces and that the ladder is fully locked. Avoid stepping on the highest rung of the ladder and don’t use aluminum ladders around electrical work. It’s also a good idea to inform everyone in your home when you use a ladder, especially if you have to place one in front of a door.
Fire
A fire might be the last thing on your mind when working on a DIY project. However, fires are a real problem whenever you are working with power tools or flammable materials. To keep a fire from getting out of hand, always have a fire extinguisher on standby. Also, think about the types of fires you might be dealing with whenever you start a DIY project and the best ways to put them out.
Fumes
Whether you are painting a room, staining a room, or cleaning a surface, fumes can be an unexpected hazard of DIY projects. While respirators are a good way to prevent fumes from becoming a problem, it’s always a good idea to make sure the workspace has plenty of ventilation. You can increase ventilation by opening windows or using fans. Also consider moving the project outdoors if you cannot ensure proper ventilation.
Dust
Many DIY projects create a lot of dust particles. Depending on the type of material, dust can be very dangerous to ingest. Always check the materials in question before starting a project and determine if the dust particles will be a problem. If the dust is hazardous, purchase the recommended dust mask or respirator to protect your lungs from harm.
Tips
It’s always a good idea to think about potential safety concerns before you start a project. This includes researching the materials you are working with and noting any hazards. Also double-check your tools and make sure you are aware of their safety hazards. Remember, you can never be too cautious when it comes to safety.
