Using a Watering Can as a Decorative Flower Vase
You do not need to spend a lot of money or even time to create a flower vase arrangement. In fact, a simple watering can suffice. Here are some basic guidelines for you to follow to use a watering can as a flower vase:
Tools and Materials Needed:
  •  Watering Can
  • Foam
  • Water
  • Flowers
  • Accessories
Step 1: Acquire the Tools and Materials
First of all acquire the tools and materials that you need. Keep in mind the type of flowers you would like to use, both in terms of color and size.
Step 2: Prepare the Watering Can
Place the foam inside the watering can. Choose a foam that is ideal for the flowers you will be placing. Make sure you have a few centimeters of the foam protruding from the upper part of the watering can. This will enable you to better fix the flowers in it. You may place fresh flowers in this arrangement. Simply fill the watering can with water, so that there will be enough water soaked into the foam to sustain the flowers.
Step 3: Add the Flowers and any Other Accessories
Start adding the flowers in the central part of the foam. Then, add more flowers around them on the sides. Keep adding flowers to fill any gaps. You could also add other accessories according to your likings, such as leaves and butterflies.
